Lewigi Posted April 24, 2014 Posted April 24, 2014 Ive had a bit of a problem... i bought some front bearings for my glanza which has ABS , i gave it to a mechanic for him to fit them but when he took stuff apart he said to me that it wasnt the right bearing kit as the metal lip on the outer seal is too small to accommodate the abs reluctor ring on the end of the drive shaft....so he said that there must two types of outer seal / lip to fit non abs and abs model. Has any one had a similar problem? Quote
Chris_GlanzaV98 Posted April 24, 2014 Posted April 24, 2014 i had this mate did you order them from camskill by any chance ? Quote
Lewigi Posted April 24, 2014 Author Posted April 24, 2014 What did you do about it? Nah I got from id workz . I don't blame the seller , I think there's just a mix up with the bearings that I need . ... Quote
