Right my HKS uprated actuator arrived from japan today, just a few questions. I have read a few posts in the technical section and have downloaded the how 2 guide to install it, people have said you can set it to 0.8 bar safely without hitting fuel cut, i have a jam fcc can i safely raise it higher or should i wait till after christmas when i will be getting my RRFPR and high flow fuel pump? cheers jon
Dont go above fuel cut with out fuelling mods.
You wont need to go above fuelcut level to feel the difference, you will notice as soon as you've fitted it that it will hold boost alot steadier without dropping off higher rpm.
Well i am going to fit my actuator tomorrow, and hopefully remove the restriction from number 3 runner on my manifold. And may possibly be getting a kakimoto racing exhaust as well. Fingers crossed :ph34r:
30lbs/ft?? :DB)
Yeah it went for 101 lbs/ft to 134.4 lbs/ft can feel a big difference :) will be going back after xmas once i get a few more things. Full ss exhaust sard rrfpr, uprated fuel pump and fmic. Be interesting to see what it pushes out once they are done
Thats awesome bro, i will be following your mods because we seem to have identical ideas etc so will be good to see what were pushin when we get our desired mods. Good luck and hope you dont run into any problems (,")
MM
