Hi All,
Is there a certain way you take the rotor arm off? I have an n/a so the rotor arm isn't bolted on like the FTE. It seems stuck on pretty tight and I don't want to pull or pry it off in case I snap something. Is there a trick to this? Should it be so tight?
Cheers,
James
