Swain cossie Posted June 1, 2014 Posted June 1, 2014 I have a glanza turbo that only boosts to 0.6 an on the diagnostic it comes up as code 41 tps sensor runs fine on the live data wen throttle pressed does not read any percentage it's a 4pin tps sensor idle switch is workin in the tps but no power !! Checked wiring back to ecu which is fine Quote
