raddys1 Posted June 14, 2014 Posted June 14, 2014 Hello, I'm abit of a noob to the world of 4efte, anyways down to business, I brought a ep91 glanza and had to 1st replace the turbo, I did this and it worked but it didn't boost up fully, a week or so later the bottom end went so I replaced the engine. I replaced it with an ep82 engine (same just with different thermostat housing plugs I believe) but now the car is still not boosting up (even less boost then last time) and when the car is on idle it is hunting like mad (revs bouncing up and down) The car is standard apart from an uprated manifold and de catI did notice a tiny hairline crack on the manifold at the top, no bigger the the length of a 5 pence (probably smaller)http://s1207.photobucket.com/user/G1991W/albums/ Quote
