tanabe Posted June 15, 2014 Posted June 15, 2014 Year:1996Model:starlet glanzaTax:6 months MOT:11 months Mileage:129,557KMDescription:Hello thank you for viewing my advert. I have for sale my 1996 N reg Toyota starlet glanza V, the car has 11 months mot and 6 months tax. The car has full papers and documents and comes with 2 keys and a Toyota owners manual. I have owned this car since 2008 and has never let me down.The car has 129,557 KM. The only problem with the car is the ABS light on but brakes are working fully.I have owned this car since 2008 and it has never had any problems but a month after the mot the ABS light came on. Engine spec:Ultra ignition leadsNGK iridium sparkplugs heat range 7Cusco turbo pipeEcu unknown but has a very aggresive map and no fuel cut, no boost cut and no speed limiter it came with the car from japanArc intercoolerSamco turbo pipesSamco induction pipeBlitz LM filter kitCusco brake stopper Sard oil catch can+Engine breatherSilkroad engine torque damperHybrid turbo (unsure what it is) came from japan on carHKS SSQV 3 specific kit for ep91 4efteTRD engine mountsGreddy Oil cooler (not fitted on car)Samco coolant hosesEngine may be cammed and balanced can`t be proven but you know it different to a standard 4efteTMD cast graphite decatApexi N1 exhaust systemtiming belt changed in 2012 with kevlar power enterprise timing belt with very little mileage on it.ID workz cooling panel TransmissionGearbox is c52 with a TRD final and a TRD mechanical LSD limited to 130MPHTRD short throw kituprated bushes on gear linkageunknown uprated clutch suspensionSilkroad RM coilovers with top mounts fully adjustablepolybushed wishbone (not fitted)polybushed droplinks (not fitted)Cusco panard rod BrakesAPP Brake lines only fitted to front not fitted to rear but will come with the carFront brake pads are acre super pads15inch forged BBS wheels with red/pink ray wheel nuts and mcgard locking nutsnewish tyres all round Interiorstripped interior ( orignal interior parts comes with car)3 point rear strut bracemomo steering wheel (not fitted)It came with lightweight door cardsorignal toyota cassette player The car comes with the followingGreddy oil cooler ( bought from ID Workz ) but never fitted2x HKS panel airfilters4x NGK iridium heat range 7 sparkplugs1x Oil filter removal cup1x New fuel filter1x New sard oil filter3x sump plugs (2 are magnetic ones)1x New sard thermostat4 new depo gauges-OIl temp-Oil pressure-Coolant temp-Boost pressure Omori mechanical oil pressure gaugeOmori electric coolant gauge4xTOM`s C2 14inch wheels new aftermarket seat rail (drivers side) sits lower than stockspare timing belt (no bearings these where used when fitting the power enterprise belt)The car comes with a spare toyota red long life coolant. Any questions call, text or message me thanks Price:£4000Pictures: Contact Details: Quote
tanabe Posted June 15, 2014 Author Posted June 15, 2014 forgot to put my number its 07927820105 thanks Quote
