bms707 Posted June 19, 2014 Posted June 19, 2014 Does an ep91 4efte have a pilot bearing/ bushing. I am changing the clutch on my buddies 4e swapped tercel, I didn't see anything in the crank when i pulled the engine out. The input only has a slight taper on the end of it, doesn't look like it needs one though, i just want to make sure.. Quote
GP82 Posted June 19, 2014 Posted June 19, 2014 Your right in not seeing one as they don't use a pilot bearing. Quote
bms707 Posted June 20, 2014 Author Posted June 20, 2014 Ok thank you much!! just wanted to be sure before re-assembly Quote
