bms707 Posted June 19, 2014 Share Posted June 19, 2014 Does an ep91 4efte have a pilot bearing/ bushing. I am changing the clutch on my buddies 4e swapped tercel, I didn't see anything in the crank when i pulled the engine out. The input only has a slight taper on the end of it, doesn't look like it needs one though, i just want to make sure.. Quote Link to post Share on other sites
GP82 Posted June 19, 2014 Share Posted June 19, 2014 Your right in not seeing one as they don't use a pilot bearing. Quote Link to post Share on other sites
bms707 Posted June 20, 2014 Author Share Posted June 20, 2014 Ok thank you much!! just wanted to be sure before re-assembly Quote Link to post Share on other sites
