yaristurbo Posted June 24, 2014 Posted June 24, 2014 (edited) Basically... When dizzy not in camshaft and spun by hand a spark and rpm signal is created Bolt the dizzy in the engine and you get nothing, not rpm cracking signal or spark Any ideas Ring me please Edited May 9, 2023 by yaristurbo Quote
triple j Posted June 24, 2014 Posted June 24, 2014 Are u using the dizzy for trigger, what version of megasquirt are u using. Quote
yaristurbo Posted June 24, 2014 Author Posted June 24, 2014 Yes 24-1 ms2version 3I haven't used ms at all, could it be the adjustment in the ecu for the throttle pots?? Quote
triple j Posted June 24, 2014 Posted June 24, 2014 Does the ms have 2 vr outputs, one is for NE and the other is for the G sensor inside the dizzy, remember the dizzy rotates at half the crank speed so it takes 2 rorations for a full cycle, setting must be correct for this in tuner studieos. Quote
yaristurbo Posted June 24, 2014 Author Posted June 24, 2014 Not sure bud, completely lost here used to motecs Quote
triple j Posted June 24, 2014 Posted June 24, 2014 http://www.msextra.com/forums/viewtopic.php?f=4&t=40490Read this man, some settings here for u also. Quote
yaristurbo Posted June 24, 2014 Author Posted June 24, 2014 Thanks for your help will try that and get back to you Quote
triple j Posted June 24, 2014 Posted June 24, 2014 No bother, was it on the car or did u just install it, there is some configuring depending on trigger choice, with the 24-1 u surely need 2 vr sensors in your ms, i only have the one in mine its a 1v3.57 thats why am using a crank trigger wheel. Quote
