doing a glanza conversion. just needed to know if the egine and dash loom has to be the same year as the car im doing it on?
think the loom is from a 1996 P Reg but ive got a R reg?
thought i wouldnt of mattered as im changin the loom and engine and puting glanza ecu in?
That's fine buddy as it has to be out of same spec, like you got a 96 spec and so is the loom so youl be fine , if you had a 98 spec one it's different and wouldn't match up to you sensors on engine etc
