Hi i just replaced the gearbox on my glanza s and there is no sign of fifth and reverse literally no movement at all from the shifter at all. It has a short shifter which is very stiff and uneasy but still had all the gears prior to the gearbox change. Can anyone shine some light on this issue please thanks.
Still not having any luck with gearbox i've swapped the brackets over, all the gears are there manually its when you attach the linkages to the bracket. The shifter gets really stiff and losses 5th and reverse...SOMEONE HELP!!!!!
