I have just put in new gauges I wanted to know what are the standard pressures of oil boost fuel air fuel so I can set them cheers
Oil on start up should be around 4 and 2 once cars up to air/fuel should be 14.4 i think
Ok so what should I set it too 4??
What about oil temp
No oil pressure should be 4 on start up and drop to 2 when idle normal
Fuel pressure should be set at 2.5 with vaccum on and you fuel/air ratio should be at 14.4
standard boost i think is 7psi
