ash p Posted July 25, 2014 Share Posted July 25, 2014 I have just put in new gauges I wanted to know what are the standard pressures of oil boost fuel air fuel so I can set them cheers Quote Link to post Share on other sites
TD04HYBRID Posted July 25, 2014 Share Posted July 25, 2014 On 7/25/2014 at 11:45 AM, ash p said: I have just put in new gauges I wanted to know what are the standard pressures of oil boost fuel air fuel so I can set them cheers Oil on start up should be around 4 and 2 once cars up to air/fuel should be 14.4 i think Quote Link to post Share on other sites
ash p Posted July 25, 2014 Author Share Posted July 25, 2014 Ok so what should I set it too 4?? What about oil temp Quote Link to post Share on other sites
DevonGT Posted July 25, 2014 Share Posted July 25, 2014 Are you on about max and min warning levels? Quote Link to post Share on other sites
TD04HYBRID Posted July 25, 2014 Share Posted July 25, 2014 On 7/25/2014 at 1:01 PM, ash p said: Ok so what should I set it too 4??What about oil tempNo oil pressure should be 4 on start up and drop to 2 when idle normalFuel pressure should be set at 2.5 with vaccum on and you fuel/air ratio should be at 14.4standard boost i think is 7psi Quote Link to post Share on other sites
ash p Posted July 25, 2014 Author Share Posted July 25, 2014 Ok mate cheers Quote Link to post Share on other sites
ash p Posted July 25, 2014 Author Share Posted July 25, 2014 On 7/25/2014 at 1:10 PM, DevonGT said: Are you on about max and min warning levels?Yes mate Quote Link to post Share on other sites
