Has anyone 9" wide wheels in a starlet or glanza? Or would they fit? The wheels I'm looking at r
16" 9j et15 4x100
Any help would be appreciated
Thanks
Edited by maguire_s
To be honest I'm not to firmilar with all this sizing n that but if I could get them to fit I would get them
Edited by maguire_s
9" wide not 9" diamter...
It's not the width it's the offset/ mine are 8" wide et+17 and they all rub slightly on the arches. i only get away with it on D2 coilovers set pretty hard.
i think the extra inch and slightly lower offset would make it a harder job to run unless you flare the arhces a fair bi
another problem i had with mine is making sure the tread is legally under the arch. i had to stretch 185 tyres onto mine to get the tread in the arch. you would deffo need considerably more stretch than that due to the extra inch and the even lower offset. would be a pain in the arse if you ask me
ovbviously they will stick out of arches lol
i have 9 inch wide by `13" drag steelies and they fit with 5mm spaces not to sure of the offset
