1st numbers are tyre width in mm
2nd is the tyre wall height as a percentage of the width also in mm
and I think you can guess the last one :p
If you have coilovers i would go for the 195/50/15 as they give a better shock absorption. Also cheaper...
If your on a decent set of shocks and springs get 45's
For a tyre i would go for the Eagle F1's, excellent tyre in the dry and wet and relatively cheap...
As mark said - if your putting it on coilovers or decent suspension drop it on 45's mate. . . thats wot mine is on...
And the best tyre for the money are the eagle f1's - but all depends if your using for just normal road use or nipping to a track every so often??!?!
