Yes you can if you can find somewhere who will make the hoses with the correct lengths and angles.
Pro's:
Less heat transfer
Same sizing throughout so there will be no steps in the pipe work when it joins into the cooler and throttle body giving smoother transitional flow.
Con's
Finding someone to manufacture them and the cost
Other companies have used mild steel pipe work because its thermal transfer properties are greater than that of other materials.
