Hey guys and girls,
I noticed a little while ago that my oil temperature gauge isn't working. Is this an easy, inexpensive job? Or (knowing my luck) be a pointlessly expensive and time consuming job?
It is weird though, when I start the car, it says its below cold, then when I turn it off (after driving for a while) it goes slightly further down...
Any advice on the matter would be greatly appreciated! I have an EP82 NA.
Cheers.
this is a comon problem, the thermostats away, its an easy job mounted on the side of the engine above the gearbox.
threee nuts and you can take the old one out and put the new one in, be gental with the bolts as they could snap ;)
hope that helps
could you please post in the right section with any of your technical quearys, saves me moving the post in to the right section
