carter Posted January 19, 2008 Posted January 19, 2008 does any one know how to fit a uprated furl pump? and one of them power boost value thing. can can one put a few pics up plz and the subject. thanks tony Quote
paul w Posted January 27, 2008 Posted January 27, 2008 Piece of piss!Take old pump out,cut the old wires,leaving enough to join the wires on the new pump to and refit it. Pretty straight forward once you look at the pump.It's under the rear bench. half hr to an hr tops. Quote
carter Posted February 1, 2008 Author Posted February 1, 2008 ok had a quike look likes looks straight forward but which wires is it i neet to cut?Piece of piss!Take old pump out,cut the old wires,leaving enough to join the wires on the new pump to and refit it. Pretty straight forward once you look at the pump.It's under the rear bench. half hr to an hr tops. Quote
paul w Posted February 3, 2008 Posted February 3, 2008 The old connector that plugs into the pump is different to the new one if i remember right. Quote
carter Posted February 8, 2008 Author Posted February 8, 2008 ok yeah seen the wire like but there is more than one wire in the the plug. going to have a go at it any way i think i know which two i got to cut looking at the new connecter. but thank mate! for the info helped alot! (ps not taking the piss)The old connector that plugs into the pump is different to the new one if i remember right. Quote
