Installing sr doors onto a na (the way I did it) both models were 1997
Unbolt wings from the car
Unbolt doors
Drill hole in A pillar for cable to pass through
There is a recessed section on the pillar so very obvious (should really paint the edge)DSC_0024_zpsehxl4el_edit_1415193124645_z
Line up new door and bolt on
Push loom plug through the new hole and plug into the matching plug in car behind the kick panel
Bolt wings back on
MAKING THE CENTRAL LOCKING WORK.
Remove trim panel/speaker from under steering wheel
Locate this plug/fuse the white one on the right
Add this relay to it
Check central locking works
MAKING THE WINDOWS WORK.
With the dials out find this orange plug
DSC_0042_zpscrplk96_edit_1415818218691_z
Fit this module
Install here, if you have taken the module from a sr it will probably have the bracket attached
Check windows work before putting dials back in.
The whole job was straight forward and was finished in a day.
If you are switching doors like I did, don't forget to change the locks over from the old doors or you will have 2 keys. I also put a remote central locking kit at the same time
Burt
  • 2 years later...
