chrisB Posted January 24, 2008 Posted January 24, 2008 Hi,Ive just fitted a blitz ss bov(second hand) to my glanza but its not very loud. . It has a adjustment screw do i need to adjust it if so what way and will i need to oil the inside?Cheers chris Quote
Glanza_Ragger Posted January 24, 2008 Posted January 24, 2008 Hi,Ive just fitted a blitz ss bov(second hand) to my glanza but its not very loud. . It has a adjustment screw do i need to adjust it if so what way and will i need to oil the inside?Cheers chrisYou tighten the adjusting screw to only let the valve open under harsh throttle letoff Loosen the adjusting screw so the valve opens easier under less pressure..Ive got mine tightened almost all the way so it only dumps when youre giving it some, and not everytime you let off driving gently around town..Just get funny looks and it sounds chav Wont really need to oil it, its aluminium so it wont rust, but may corrode a tad, if so just give it a light spray of wd40 to release it a tad.bo Quote
chrisB Posted January 25, 2008 Author Posted January 25, 2008 You tighten the adjusting screw to only let the valve open under harsh throttle letoff Loosen the adjusting screw so the valve opens easier under less pressure..Ive got mine tightened almost all the way so it only dumps when youre giving it some, and not everytime you let off driving gently around town..Just get funny looks and it sounds chav Wont really need to oil it, its aluminium so it wont rust, but may corrode a tad, if so just give it a light spray of wd40 to release it a tad.bohi.Thanks for the info ive just tried the adjustment screw and it works.cheers Quote
Glanza_Ragger Posted January 30, 2008 Posted January 30, 2008 hi.Thanks for the info ive just tried the adjustment screw and it works.cheers No worrys bud, not everybody likes the blitz ss sound..But i do..The blitz ss and the hks ssqv are my favs Quote
