alright need abit of help. i need to change my door. you know the door pin, what way do i get it out, knock it up or down? when i have got the pin out can i use the same pin or when its out you need a new one?
The pins tapered isn't it ? ( fat top - skinner bottom ) if so it can only go one way :D
I can't see why you wouldn't be able to use the same pin as long as you don't damage it
James
James
do i knock it out up or down?
