Flynn Posted March 8, 2015 Share Posted March 8, 2015 Has anyone done a "how 2" on fitting a panhard rod to an ep91 or can anyone give me some advice (easily done by a bit of a retard with a decent toolbox?) I'd have a hunt but I'm on my phone and it's a bit of a mission.Want to get it fitted before the cars in for tracking, or would I be better getting them to fit at the same time? Quote Link to post Share on other sites
Idrees Posted March 8, 2015 Share Posted March 8, 2015 Easy DIY job with axle stands and a trolley jack. 1. Do all the obvious things such as remove wheels, get the car on stands etc. 2. Use a 17mm socket on a breaker bar to remove the nut holding the panhard rod from the axle3. Use a 17mm socket and spanner to remove the nut and bolt holding the rod to the car4. Pry the car off, it can get a bit stuck on the axle Remember to have a jack under the axle to save it dropping down on you once the panhard rod is undone. Sorry they are not the best instructions (using my phone) but it gives you a good idea. Quote Link to post Share on other sites
Vturbo Posted March 8, 2015 Share Posted March 8, 2015 I fitted mine outside my house, it was a fairly easy job to be honest, literally just two bolts, the hardest part was getting them undone. Quote Link to post Share on other sites
Flynn Posted March 8, 2015 Author Share Posted March 8, 2015 Cheers Idrees that's way more help than I was expecting gotta love this forum sometimes Quote Link to post Share on other sites
Andy32 Posted March 7, 2016 Share Posted March 7, 2016 Just a quick question just bought a whiteline panhard rod and when it turned up has a spacer/thick washer in a seperate packet with it. Any ideas if this has to used and where..?Thanks for any advise. Quote Link to post Share on other sites
olidaviesuk Posted April 10, 2016 Share Posted April 10, 2016 Adjusting these correctly is the trick to using them - so many just adjust them to the length of the std bar - ideally you need it done when you get the car 4 wheel aligned - because of the way the rear beam works when you lower the car with the std rod the rear beam will sit more to one side than the other - you can get it back to straight by shortening/lengthening the rod. Quote Link to post Share on other sites
