car will stall on deceleration or idle when stopped at light, sign, etc. It won't start for 15~30 minutes. When I do get it to start, Gas peddle all the way in and hesitates (stays at ~800 RPM steady) until it burns off fuel and then rises RPM rapidly to match WOT.
fed up
ignitor is new/DIs is new/spark new etc
any ideas ??"
Coolant temp sensor?
i do not know how cani check it ,because on the EMU i can see the voltage ,and the degré...it seems working normaly
can you tell me where can i get by internet this part
i am in reunion island ,and there is no 4efte parts to get , i have to take all from england
thanx
in fact i need the part number to find it??
is is the same as 4efe?
Edited by ramses
can it be the IAC valve or IAT ??
because this is very strange , i can drive during 30 min and after that will stall on deceleration or idle when stopped at light, sign, etc. It won't start for 15~30 minutes.
After that i can crank it again and run etc etc ...
Edited by ramses
