hello,
I have finally wired up the sub and amp tested it but the only way I can see to get the red Postive cable to the battery is drilling a hole in the firewall, I really don't want to go this route is there another way please help. Toyota starlet sportif
Lift the carpet from the passenger side under the glove box, your find a black bung pull that out and your have a clean way through the firewall.
If I remember correctly it's the same on the drivers side aswell :)
James
  • 2 months later...
