Cattanach Posted March 31, 2015 Posted March 31, 2015 Basically from cold when going into 2nd quickly it grinds hugely but will go in just not a pretty sound! If changing gear slowly it slots in nicely without any noise.Once cars warmed up it goes in a lot better but still grinds slightly if changing from 1st quickly!All other gears are fine/smooth, it only grinds when the cars moving.This sound like a problem with 2nd gear synchro Or hopefully something simpler ?Worth giving the gearbox oil a change and seeing if that helps ? Quote
Ryan_EP82 GT Posted March 31, 2015 Posted March 31, 2015 (edited) Mine does the same mate though if i shift slowly into second it doesnt grind. You said it though, 2nd gear synchro and depending on how long its been going on for the teeth on the engagement hub could be damaged. Oil change will be good for it but wont take away the grinding, best off getting the box rebuilt or get a replacement, 2nd gearset is the dearest to buy im near sure its about 290 odd quid. Edited March 31, 2015 by Ryan_EP82 GT Quote
