J40k-mo Posted May 27, 2015 Posted May 27, 2015 A mates got a td04 turbo from a Subaru, it doesn't fit for obvious reasons that subarus are top mounted, So you have to spin the housing around to make it fit. But I am going to have to also spin the inlet side so that the hot pipe (to cooler) isn't facing the engine block and the intake for the filter faces the front,But if I was to do this the turbo isn't matched up for the actuator to fit, the blot holes are the other side and don't line up to bolt on. What's best corse of action ?Is there a bracket people have already made for this etc??Any help would be greatThanks Quote
