Car runs and drives fine then all of a sudden car splutters and cuts out like its ran out of fuel, then won't start, just turns over for fun..
Then it will fire up, when it feels like it, but when it does it's like its running out of fuel and struggles to start. But then once fired up its sound,
Problem happened on mapper, and on ecu cycle it says when it won't start injectors arnt opening at all.
So must be something fuel related? Pump seems to buzz up like normal tho when it's turning over,
Could it be a daft sensor?
Any help please
Cheers
Injectors blocked!? Could be a shout. Mines has a problem like this. But it's with my idle. Will idle fine then when u drive it for a bit then stop at a junction or lights it drops off idle and cuts out then it starts fine but drops off again so a need to stop and adjust the idle screw so the revs are up. I've been told to try a good set of injectors as they could be blocked...
Edited by daveEP
