Flower Posted June 12, 2015 Posted June 12, 2015 Hi guys,I have fitted a "ep 95 trd" rear mount on my Glanza as the OEM one was shot and I seem to have a horrific judder now it literly chatters your teeth.(May be the clutch athough it's done 500 miles)The issue was bearable until I put these JD tunning left hand and right hand and now it's even worse ! I went to fit the poly bush to the rear mount and the bush is way to small. So apparently it's a OEM lsd mount ? Would a 4efe rear mount fit ? And could it be causing this problem ? Any opinions appreciated !! Cheers Quote
