KPJUK Posted June 16, 2015 Posted June 16, 2015 Hi everyone, I'm almost done with my 4E-FE conversion for my 1990 Corolla, however the engine starts and cuts immediately. I'm certain this is an immobiliser problem and after wiring in the immobiliser computer (not hooked into door switch though) and taping the key to the antenna ring I still can't get it started. Is there a way of resetting the ECU to accept the code the key is sending out? Failing that is there any means of finding out what code the ECU wants to see so I can emulate that? KP Quote
