gazza g Posted June 29, 2015 Posted June 29, 2015 Hi what kind of compression should I be looking at on my forged engine? Trying to pin point a misfire so whilst changing plugs I did a test, -all sat around 200 psi but when a wet test performed it hit 250 psi? This to me is very high, I thought forged engines ran 150ish psi low compression Tests were done on a hot engine Quote
AdamB Posted June 29, 2015 Posted June 29, 2015 Depends on the spec of the engine, who built it etc. Most forged engines should read about 150-180 really depending on spec. 250 seems a bit high even for a wet test with such low compression motors even stock. Quote
