Gone out for a play in my Glanza earlier, on the way back I lost all boost, an noticed my bottom end has started knocking, would that cause me to lose boost? Or have I got another problem else where? Thanks
you wouldnt normally loose boost. you might have a vac leak or blown a pipe.
Is it defo bottom end knock and not release bearing or injector clicking?
Get a vid up
I'll get a vid tomorow, pretty sure its bottom end, I had a quick check over all the pipes an cant see anything, just curious why its both happened at the same time :/
