Hello from Portugal!
Most accurate from the Azores (the little set of small islands in the atlantic you probably never heard of hehe)
As the title says, Im in need of a wiring loom for a mk1 EP82 starlet, i need the loom from the headlights to the fusebox (included) and the wiring loom behind the dashboard....so pretty much everything aside the engine loom and rear loom
Can anyone of you guys supply this? Reason is a messed up swap on the current starlet, sniped and snaped loom.
Please say yes! It would be the only ep82 running in portugal!
Thanks
