dangeestarlet Posted November 26, 2015 Posted November 26, 2015 Anyone know if I can use a gasket off any car which is the same as the cat to exhaust gasket on a 4efte the triangle 3 bolt one. Need one off the shelf in a local motor factors on weekend if possible thanks any other uk toyotas fit? Thanks Quote
Ep82gi Posted November 26, 2015 Posted November 26, 2015 Just use high temp sealant mate works every time n if you take it off again just scrap the old stuff off n use the sealant again give it time to dry mind. It want blow if you buy half decent stuff Quote
