Would anyone have a idea what i could get for my starlet gt turbo . The bottom end bearing casing has cracked causing a nocking noise at sertain rpms and loads .the car has a stage two forge engine , tuning developments hybrid td04 , full decat ( blitz nur spec r) , emange blue and all the other sort of supporting mods you would expect (blitz duel sbc, front mount, clutch, injectors, half size rad ,tein coil overs ect) . I would break the car but i dont have the time space or tools to do it hence why i was seeing if anyone would want the car as a whole . The car still starts and runs but obviously its not healthy . Ill answer any wuestions if anyone is interested . Id also throw in the 2xblitz brw type 2's and the 2xssr mk1's . The body work isnt great (the black panels have been rattled canned byt the previous owner and is chipping off) no rust though (apart from a slight patch on the bonnet) and no leaks . The interiour is 85% complete as i was in the process of slowly putting it back together and has also been well sound proofed .
post-10862-0-91641600-1452367732_thumb.j
post-10862-0-00573200-1452367752_thumb.j
post-10862-0-29137400-1452367774_thumb.j
