X_Milch_X Posted January 10, 2016 Posted January 10, 2016 (edited) Hot Cold - Dash sensor not working - help needed Anyone know where i should check, Can't see any loose connections? Edited January 12, 2016 by X_Milch_X Quote
X_Milch_X Posted January 12, 2016 Author Posted January 12, 2016 Bump, Any help appreciated..... Quote
Ep82gi Posted January 12, 2016 Posted January 12, 2016 Try your gage temp sender in the bay should be a single wire plug on the thermostat housing bro Quote
X_Milch_X Posted January 12, 2016 Author Posted January 12, 2016 Try your gage temp sender in the bay should be a single wire plug on the thermostat housing bro Thanks bro - all fixed now must have slipped off when the after market rad was fitted. Not sure if this will help anyone else but it was the cable with blue tape that was loose from the red circle Quote
Ep82gi Posted January 13, 2016 Posted January 13, 2016 Thanks bro - all fixed now must have slipped off when the after market rad was fitted. Not sure if this will help anyone else but it was the cable with blue tape that was loose from the red circle glad you got it sorted dude Quote
