Fitted a decat and greddy boost gauge on my glanza, it's also got the high low boost bypassed. I've set it to 0.65 peak as I know that's what they run standard but it will now go past that to about 0.70-0.75 bar is this doing any damage it over boosting? As fuel cut is 0.85 bar anyway? And would having an adjustable acuator stop it going over? Quite confused if it's damaging , Thanks Dan
It's safe until .85 bar if you don't want boost creep port out the wastegate. And fitting a new actuator will only be good for it as the stock one gets knackered over time.
