bowen Posted March 4, 2008 Posted March 4, 2008 is there anyone here who can run me through fitting one of these and is the a specific fuel defender for the ep82? thnks Quote
Glanza_Ragger Posted March 7, 2008 Posted March 7, 2008 is there anyone here who can run me through fitting one of these and is the a specific fuel defender for the ep82? thnksI hope youre not just running a fcd and turning the boost up bro?Craig. Quote
addz Posted November 18, 2008 Posted November 18, 2008 I hope youre not just running a fcd and turning the boost up bro?Craig.What else should be changed / adjusted? I'm guessing rolling road to see if fueling is right etc. Quote
Glanza_cl Posted November 18, 2008 Posted November 18, 2008 What else should be changed / adjusted? I'm guessing rolling road to see if fueling is right etc.you need a rrfpr at a minimum to set up the fueling with a fcd, if you want to run alot of boost and power a boost controller or advanced fuel controller will help Quote
addz Posted November 18, 2008 Posted November 18, 2008 To run a RRFPR an upgraded fuel pump will be necessary too.I was looking at the 1Bar mark but there seems to be a few more upgrades that are required to get a safe 1Bar without starving the engine. Quote
