Fifress Posted March 6, 2016 Posted March 6, 2016 Hello, I'm currently on a conversion progress (right handed ep82 to left handed ep8*) so I can run a turbo starlet on my country...Got the engine runnning recently after being stored a few years, runs OK, heats up a bit...but the main problem is I've got the radiator fan running whenever ignition is on and a high idle....don't have the cluster plugged in yet (mk2 loom and mk1 cluster, needs rewire). Sounds like idle is at about 1500 -1800 rpm... I know when you remove the A/C you need to bridge some conector to stop, at least, the rad fan, but since I didn't remove it myself, I don't know wich one it is. Can someone help me with this? Some photos maybe?If interested, its a mk1 Auto ECU, mk2 loom, turned to manual...removed all extras including P/S and A/C...these parts will be for sale if someone wants them.. They were in working order when the car was stripped 3-4 years ago. <Thank you Quote
toymotaadam Posted April 16, 2016 Posted April 16, 2016 There plug you removed for the air con near the righ hand side head lamp you need to bridge it .grey plug Quote
toymotaadam Posted April 16, 2016 Posted April 16, 2016 I don't think it will solve the high idle but it may just need cycle with the radiator water Quote
