Very easy way to turn your foglights yellow just like our friends over in Japan!
What you will need...
A4 Sheet of Yellow Tint Film
Clean Cloth and Water
Heatgun/Hair Dryer
Sharp Blade
Use your rag, wet it and clean the front AND sides of the fog lights, basically anywhere the vinyl will touch, once done dry them off with clean towel.
Cut the A4 sheet in half so each peace is big enough to cover your foglight with extra overlap then peel your film and place carefully on the foglight.
From the middle of the light outwards, push all bubbles the out and make sure the vinyl is down all over the surface of the fog light,
Once you get to the edge of the light get your heat gun or hair dryer out and heat the edged and pull the vinyl tight so it sits nice on all the curves and edges.
Once this is done press it all down round all edges with your thumb just for safe measures. Get your sharp blade and cut round the back of the fog lens leaving a little bit of extra vinyl 1-2mm to tuck round the lens.
Once you have done this get out your heat gun / hair dryer and heat up the vinyl till it tucks itself round the back of the lense and push in with your thumb for safe measures.
All Done!
Vinyl can be purchased from a Trader on UKSO called Stick-2-It.
Recommended Comments
