Keri-WMS Posted March 13, 2010 Posted March 13, 2010 There are three WMS 4 pot brake kits to fit Starlets with 55mm hubs (ie 55mm disc "bore"). The kits fit with the heat shield only needing bending and trimming slightly and are great for cheap pads / discs in the future (see prices), and will fit under most 15's in the case of of the 275/277 kits and under most 16's in the case of the 295mm kit (see profile .PDF files, the idea is you print them, check the scale is 1:1 then stick the printout to card, cut it out and try it inside your wheels before buying! ). Specs are: - 6061 T6 Aluminium calipers and pistons, CNC machined from billet and hard anodised (1.38"/1.38"). - 6082 T6 clear anodised brackets, with VERY strong 431/303 stainless steel threaded inserts, "solid" type not "helicoil" type (this system is strong enough that we found during testing that an M10 grade 12.9 bolt will actually stretch before the inset fails!). - Grade 12.9 cap head bolts 4 POT KITS (each includes calipers/brackets+inserts/bolts etc/discs):4P107-S - Normal 275x22 size kit with best wheel clearance (printable clearance test profile: 275x22 kit PDF ) = £485.00+vat4P108-S PROPOSED KIT - Smaller 260x25 size kit for 14" wheels (printable clearance test profile: 260x25 kit PDF ) = £490.00+vat4P109-S - Heavy duty 277x25 size kit with more thermal mass (printable clearance test profile: 277x25 kit PDF ) = £.....+vat (currently £550+vat but HAS TO BE GROOVED (plain is £575+vat). Discs are £122+vat/pr GROOVED or £137+vat/pr PLAIN!)4P157-S - Biggest 295x26 size kit (printable clearance test profile: 295x26 kit PDF ) = £555.00+vat PLEASE NOTE - Due to the deep disc we use on the large 4P157-S kit, it actually gives you 2.5mm MORE OFFSET CLEARANCE than the smaller 4P109-S kit! So try the templates, don't assume the bigger kit won't fit your wheels...... PLEASE ALSO NOTE - The new T20-S caliper is 1-2mm bulkier so bear that in mind when using the current/old T20 caliper based PDF clearance test profiles!!!!!!!!!!!!!!!!! OPTIONS: - Grooved discs are offered as a service, and add £40.00+vat/pr. - EBC Reds are £POA+vat/set - EBC Yellows are £POA+vat/set - Ferodo DS2500 (fast road) = £62.00+vat/set - Ferodo DS3000 (race) = £63.00+vat/set - Earls braided lines (to fit WMS caliper threads) are £51.00+vat/pr SPARES: - Replacement 275x22mm discs are £53.00+vat/pr - Replacement 277x25mm discs are £122+vat/pr GROOVED or £137+vat/pr PLAIN - Replacement 295x26mm discs are £109.00+vat/pr Here are the photos of the 275x22mm 4P107 kit: ...here's the 277x25 4P109 kit, note the thicker discs. And here are photos of the 295x26mm 4P157 kit, note how the bracket "ducks" into the deeper disc, this increases wheel clearance meaning less chance of needing spacers!: ------------------OEM fit parts----------------- EP91 etc front brakes (pad shape as above): 254x18mm front discs, 43mm high, 55mm bore (same as Toyota 43512-16080) = £TBC+vat/pr EBC Red front (fast road / trackday) = £TBC+vat/set EBC Yellow (fast road / trackday / race) = £TBC+vat/set EBC Blue (RACE ONLY) = £TBC+vat/set Ferodo DS2500 (fast road / trackday / race)= £TBC+vat/set Ferodo DS3000 (RACE ONLY) = £TBC+vat/set Carbotech AX6 = £POA (£140+vat minimum) Carbotech XP8 = £POA (£140+vat minimum)
