german4efte
Member-
28 -
germany
german4efte's Achievements
still having problems gear selecting.
german4efte replied to grant_901's topic in Drivetrain & Transmission
your problem is crazy, dont realy have a idea or heard such problems before you bleed the clutch correct? possible air is in the line and when is warms up the air expands in the lines? you have th option of working at your own car? any chance of changing gearbox for test? my GT gearbox had little problem, so i put in 4efe gearbox and sometime i couldnt get the 1st gear out....dont know, whats happening, but i know its INSIDE ...so i know clutch and shiftcable is ok -
check oil, change oil and try again.
OEM MR2 W3 LSD diff from MR-S fitting to starlet?
german4efte replied to german4efte's topic in Drivetrain & Transmission
hihi....no problem i know my english is not best one i live in germany and only learned school english (long time ago) but in gemrnay i never found help or parts for my 4efte project so i need help from all over the world. Especially finding parts is hard -
my problem is, the MR-S DIFF doesnt FIT ! to thick ! ! fitting it self is no problem, no magic. Where can i find OEM AE111 LSD? Quaife will be cool option, but VEEEEERRRRY expensive ! Helical LSD would be great, no service cost. only put in and ready KAAZ service is crazy, every 3500-5000miles new oil, KAAZ oil !..NO ! ! -
Oilchanges at LSD, service infos?
3000-3500 miles at one yeart i think so i have to change it every year with my engine oil (sommer season car) because of this i think about, in some years i ll get more expensive thank now buy a helical/torsen LSD. and i hove no idea how long a CLUTCH-Live would be in a LSD....so i have to change the clutches also every xx.xxx miles... -
I am planning to fit a LSD in my gearbox. Found the following options KAAZ (CLUTCH) TRD (CLUTCH) QUAIFE (Helical) OEM AE111 BRZ CUSCO Because of Price is found KAAZ interesting, BUT they say after 5000mile oilchange because the clutches work. For KAAZ official is used KAAZ OIL, every 5000miles cost of 50GBP TRD also uses CLutches, in past TRD also build helical, but not available today. So the gearbox oil also have to be changed? dont find ANY info after what TIME / miles this is requiered. WAHT OIL is used? I can get castrol 75W90 with LSD additive. quaife, OEM AE111 and Cusco should no have these service cost, but the are expensive and rare. so what to buy, i dont realy want to change every year the gear oil, would be expensive . I dont use my car daily, but fast road ( i like fast cornering) and some 1/4 mile. what would be the best option of LSD for my use, clutch or helical/torsen?
Hi, i search a LSD from quaife, trd, kaaz, cusco for my c52 gearbox. Dont need OEM visco lsd. Want to upgrade my non LSD gearbox possible some want to sell. shipping to germany must be possible
this gearbox is already found....price is ok, but what should i do with the 6 speed gearbox....dont realy want fo put it in my corolla, the gear ratios are not so good in my opinion, i always have to shift....i`ll think about thank you for your help -
@pockrockgtti thank you for these accurate post. you tryed it? this is no good answer for me, but so i can save the re-shipping if your sure i watched at TRD lsd page, these also got different TRD numbers. So i think its for sure that this wont fit :-( -
and what kind of LSD is a torson? I know how it works, but does it also lock when i roll in coasting mode?? or is a torson no problem at FWD car? -
@Stu the oem MR-S lsd is 2 way? -
i got a corolla AE110 5 speed and fitted an 4e bell at the gearbox. i have a 8 bolt diff. i dont use OEM CT9 use hybrid... -
thank you, the torque could be problem, dont realy know what my car gots. I use tongs CT9 and mapped MAX 1,2 bar for short overboost with 370cc injectors....it feels like much torque, would be bad if the OEM N/A diff break. This damage my complete gearbox The phantom grip seams shit...dont realy believe this can work. Some honda drivers use it an got bad damages (google said) -
Hi can somebody tell if the OEM LSD diff from MR-2 fits in a Glanza gearbox? think its also an C-family gearbox. would such LSD stand Glanza with 180PS-190PS ? ths MR2 LSD also got 8 bolts like glanza DIFF WHAT IS THIS FOR AN KIT? http://www.mts-motorsport.com/PhantomGrip-LSD-Kit-TOYOTA-STARLET someone used it?
yes i use standart relay and yes like this i plan. like its written in the manuals chapter 14. But there are 4 wires if only one is needet, i could swicht 4 relay? dont believe. max 2 options can be switched iam not sure about wiring
