chrisholly
    157
    clevedon
    driving paintball and watching telly
chrisholly's Achievements
  1. Will u take 120 for it mate?
  2. Is this still for sale
  3. chrisholly
    please close
    no longer needed
  4. Where are you based
  5. Aha didn't know it had a tps not checked the butterfly it might be suck as been sat I'll update on tps and butterfly wen I finish work not checked
  6. Yep right Oil fuel everything on the car us new bar the engine and she'll and sensors and wires but all wires checked all new Vac pipes so no spilts All earth's are good and tested map sensor not been tested but have checked all since new ecu jam removed fcd and help the problem a little but not disconnected the battie all the timing is set from the.book all new cam belts dizzy and leds down to plugs are new The problem is the flatspot in mid range same place no change at all its always there little tourle is OK drives fine right at the top if I have my.foot right down don't wanna go anywhere fast till I lift of alittle New turbo aswell
  7. Mine didn't have any fuel part from fuel light thn brimmed it
  8. Yea trisk about 1 and ahalf years but it's had fresh fuel tho?
  9. No I got it from someone on here 1bar not standard And I have.tested with hand pump etc works fune
  10. Don't have a fpr or played with fuel all standard injectors was working fine should be OK but changed the turbo don't.think that would matter will it
  11. No faults or engine management light on was on was a Vac fault but have fixed and no fault Problem still there
  12. Try and change your oil and plugs might help to keep it cooler try mixing abit of coolant with water in your rad
  13. Hi my car drivers fine till it go's over. 0 into boost put my foot down feels like no midrange power till I lift my foot up off the peddle alittle and it pulls till I put my foot down more again Checked and tested map sensor Timing Vac piles New plugs New leads New dizzy Everything to do with the ING ;(
