Sandham
    350
About Sandham
  • Birthday 05/21/1993
    Leeds
2303 profile views
Sandham's Achievements
Member (4/8)
  1. Bulb not working at all all others bar drivers front with hazards
  2. Put 15l fresh super unleaded in this morning mate. Was left with more or less nothing in it beforehand.. Also suffering from a very low idle when warm (500ish rpms)
  3. Ive finally got my car back together after a winter with no bonnet! All seems ok however ive got a misfire thats completley random and very slight. Was worse but ive swapped the coil and igniter for a tested one.. Dizzy and rotor were fitted just before it came off the road. Leads seem ok but will be replaced monday, anything else to look for? Td04 @0.9 with a jam fcd. Was running for a year spot on untill i stopped driving it.
  4. Hi im having troublewith my drivers side indicator, I've replaced the bulb however cannot get the indicator flash. All the rest of the lights in the car work fine.. I've checked the fuses and they are all okay as well, I'm just wondering if there's anywhere else I should look return return backspac i've checked the fuses and they are all okay as well, I'm just wondering if there's anywhere else I should look? Thanks
  5. looking to buy a shell in a few weeks without and engine and box to put an engine i have in.. got most parts like headlights grille so if they arent there that isnt too much of an issue based near leeds
  6. Sandham
    Gt bonnet ect
    Would need quadlights mate, What sorta price am i looking at for everything? Im in leeds... Im getting my new slam panel welded in soon hopefully but just lost my job so money is very tight
  7. Sandham
    Gt bonnet ect
    Bump
  8. Sandham
    Gt bonnet ect
    Bump?
  9. I didnt think so... Had someone trying to sell me one saying they fit! In that case i need to hunt one down
  10. Hi im trying to find out if a glanza front slam panel ( the frame at the front of the car the headlights fasten into) will fit a gt as my gt has taken a knock and i can get hold of a glanza front section... I know ill have to do some work to male my headlights fit but other than that can it be swapped once ive drilled the spot welds and removed my old one? Added a link to a old thread on tgtt by amjad?. Its the black part im reffering to http://www.toyotagtturbo.com/forums/showthread.php?80661-EP82-Slam-Panel&highlight=Slam+panel
  11. Sandham
    Gt bonnet ect
    Anyone got a passenger wing, half size rad, front bumper, bonnet grill and quadlights? Surely someone has a rear ender with a good front for breaking? Im in leeds but am happy to have things posted. I know it may take a while but thanks for any help offered
  12. Hi im running a walbro pump and i know they whine.. However mines started squeeking more so when under throttle. The car also occasionaly struggles to start and sometimes idles funny, is this likely to the the issue? Thanks
  13. Bought a jam fcd from dan, arrived at my door the day after i payed! Top seller
  14. Tried blocking my pcv at inlet side and leaving to atmosphere engine side and my car wouldnt idle at all? Just need to try clean my throttle body and set my tps up?
