Neo95
    210
About Neo95
  • Birthday 09/14/1995
    Coventry
    Glanza Building!!!!
3346 profile views
Neo95's Achievements
Member (4/8)
  1. As titled, Im after a good condition/spec fully forged engine. Cash waiting. Location not an issus as long as in UK. Thanks in advanced Neil.
  2. SOLD! Please lock!
  3. Bump. May break if any ones intrested.
  4. Price drop!
  5. Bump it up!
  6. Coventry.
  7. Sorry for the late reply, Standard cams and the crank was reground when built.
  8. BUMP! Open to all offers need this gone now!
  9. SOLD! Year: 1996 Model: Glanza V MOT: 27th May 2017 Description: 1996 Toyota Starlet Glanza V for sale. Time has come to say bye. This is a fully forged Glanza V, well looked after built to a very high standard. Running healthy at 283.5bhp an has all the supporting mod to go with. The car has had a full respray since then it has gained a couple of nocks and bangs since. i.e car park dink in drives quarter not huge but noticable. as seen in the pictures the boot has couple of dents in aswell as the bumper has a paint crack from a car running into the back of me no major damage on structural stuff was only after pulling off from a set of lights. Since engine was forged it has covered around 8500 miles, I have serviced the engine every 1000 to 1500 miles. Car its self has covered 145250km. All this car needs to become a great little pocket rocket is a built gearbox. Number Plate NOT included in sale. Will be back on original plate! Current Spec: TM Developments Fully Forged Race Engine 75mm Wossner forged pistons PEC forged conrods 1.9mm Athena metal head gasket Fully stripped and thoroughly chemically cleaned Block rebored, crosshatch honed Cylinder head stripped and cleaned, valves re seated, new valve stem seals Cruise valve springs Head ported New Head Bolts New Toyota oil pump New water pump New Power Enterprise Cam belt New tensioner kit New oil sender switch New thermostat All new gaskets and oil seals TM Developments rocker cover NGK Iridium Spark Plugs (Heat Range 7). Zisco K26 Big Power Turbo Kit Tuning Developments 255LPH fuel pump Sard FPR Zisco fuel rail Denso 430cc Injectors ID Workz half sized rad Roose coolant pipes Full Greddy E-Managment Blue GFB G Forces electronic boost controller Blitz turbo timer Full map/dyno at Tuning Developments JPerformance FMIC with custom boost pipes Full 2,75inch Stainless steel heat wrapped exhaust D1 Spec coilovers (Rears need a re-build as leaking oil) TRD Quickshift Brand new TurnOne dished steering wheel Sparco REV Plus bucket seat (FIA in date) Flocked dash 15” Enki wheels Toyo proxes all round Standard “Uprated” front dices and pads. Stripped rear And all the stuffed I’ve missed! Currently the only bad bits are that the coilovers are in need of replacing or rebuilding this has also caused the front tracing to become out making the front tyres castled. Aswell as having a “standard” gearbox. Any question, things that I have missed or more pictures don’t hesitate to get in touch. 07794700352 Please text first as work. Open to all sensible offers! Price: £5600 ONO Contact Details: 07794700352 Please text first as work. Open to all sensible offers!
  10. Hi people. I need same help my efi fuse keeps blowing anyone had this problem before or have any ideas what this could be? Cheers Neil.
  11. So ... As titled really, I after a set of good brand good condition coilovers for my EP91. Cash waiting! Cheers Neil.
  12. As titled. Anywhere in or near the midlands. Cheers Neil.
  13. Thats ace. Cheers thanks alot lad!
  14. Oh right where can i grab one lf these from an this will not effect the performance?
  15. Hi, I am currently running 285bhp with a 2.75inch strait pipe, Im booked on at rockingham an there sound limit is 98db. My question is I'm guessing this ig going to be over the limit an what is the best/quickest way of silencing it down? Thanks Neil
