Ja99a
    10
Ja99a's Achievements
  1. Can anyone help, I dont understand how to turn on the rear heated screen, I have a blanking plate where I think a button should be, it has a picture of the rear heated screen (the symbol). After pulling it out it's not a button, just a blanking plate. (it does look like a third button on the dash though) next to the hazzards and boost limiter buttons. How does this thing work? Help?
  2. What is the genuine oil filter part number for a 1994 Starlet GT turbo (4efte). Cheers Guys
  3. Guys, Mine did exactly this and it was the gear box attached to the motor that was jammed, the circlip that holds the gear down had popped off and was jammed in the worm gear, this allowed about 3" of movement before it jammed the gears up solid. I suggest you strip it and take a look its pretty simple stuff and easy to do, and could save you the £112+ that Toyota seem to want to charge for the part. Good luck. Oh and the runners do get very dry and sticky on the glass, I would suggest using silicone lube rather than WD40 as the silicone will not rot the rubber runners at all.
  4. PHEW! - I was Worried
  5. Guys I have looked on the JAE 2007 show guides and as far as I can see, I cant see a UKSC section. Anyone know exactly where the club stand is going to be sited? I have resorted to looking on the lexus sites guide as our JAE map doesn't have any labels. http://www.lexusownersclub.co.uk/forum/ind...showtopic=38184 No sign of a UKSC stand and I have looked for ages can we get an updated map with a circle or summut? Cheers Mike F
  6. 1) Mikey Jay 2) Idrees_SR 3) Stevie B 4) nightSpirit 5) Wings + 1 6) Oli (dribbling) 7) Toymota Enzo + antorage 9) shelly_star 10) keirz 11) rob_bower 12) nanglebadger 13) Sparticus (IF I can get a driver for my car ) 14) Badger_GT 15) Streetracer_starlet 16) scutch0 & followers 17) woody + 1 or 2 passengers 18) muddyell + prob 1 passenger(may not have back seats tongue.gif ) 19) Kelly and Ben_j (not sure if in bens or seperate cars tho yet) 20) miracle411 (aka Rick) 21) Daz + 1 (No starlet as i dont own 1 no more but yeah always spend most of the weekend on the starlet stands still cus your such a good bunch of peeps ) 22)BoostJunkie 23) Bourkey (probably 1 or 2 passengers) 24) Fishy89 & 1 or 2 passengers 25) Starlet Nath (Hopefully Geo is gonna pick me up on the way past? ) 26) Glanza_Ragger (Craig, heading up with a mate who also owns a starbo) 27) Paul W Mikey owes me a pint so i gotta go for that! 28)Alexkp60 (new to the forum would like 2 know how to get tickets and stuff please 29)Alexkp60`s other half 30)Rick 31)Harrison 32)Dave 33)Kennedy 34)Meech and a Friend (Not 100% sure though) 35) Big T SR 36) glanza_matt 37) 59bhp with 3 freinds 38) Ja99a aka Mike F (EP82) Where the smeg is the UKSC stand I cant see it on the JAE map diagram thingy?
  7. Camping over the weekend 1.Enzo, plus five mates 2.Rick 3.Mikey Jay 4.colin aka BoostJunkie 5.Kevy-Glanza 6.Phil aka Nanglebadger + Mark (my bro) 7.rob_bower and Missus 8.Fishy, and 2/3 mates 9.Stevie B 10.Mr Ti (Michael) 11. DazzaMR2 + 1 12. Starlet Nath 13. Ja99a aka Mike F + 1 Saturday 21st Streetracer_starlet (G) oli_h Sunday 22nd scutch0 + followers Streetracer_starlet (G) oli_h possibly if its worth the trip back up shelly_star glanza_matt (poss)
  8. Hey Guys is there a Starlet stand? I am going but need somewhere to park.... Put me down as defo as going all three days.
  9. I gutted my cat today, easiest job ive done in ages and in the rain... Used to the joys of MR2 Turbo ownership where every job takes 2 days with the engine out LOL. Take time means if its tight use plenty of WD40 and wind forwards and backwards to free the bolt etc. Basically gutting the CAT steps with times without breaking anything are: Job Time Activity 1 00:05 Jack up at the front (I used ramps). 2 00:10 Remove 4 bolts holding two front undertrays at the front, pull appart, use plenty of WD40 and take time. 3 00:05 Unbolt the exhaust stabiliser tap the clamp down, use plenty of WD40 and take time. 4 00:10 Remove heat shield from CAT, note its a good Idea to use a 1/4 ratchet with a short extension bar. 5 00:01 Undo clip on temp sensor, its a tricky begger 6 00:10 Undo the four main bolts that hild the bottom part of the cast manifold onto the CAT,use plenty of WD40 and take time. 7 00:02 Pull bottom casting part off and push to the side Tie up with some wire I tied it to my aircon pump. 8 00:10 Bash the crap out of the CAT brick with chisle until it falls out. 9 00:01 Check for cat brick debris in bottom elbow and metal rings \ gause found in cat housing. Refit all parts 00:26 So to gut the cat on my EP82 quad lamp took about 01hour 20mins approx Powerwise its a bit more responsive and seems to want to give a bit more at higher revs, also seems to have given me 1 or 2 psi gain over stock, My car is totally stock apart from this mod and it appears on the stock Boost gauge to reach just a sliver before the + line now whereas before it was on the graduation before. In terms of Mods I would rate this 6/10
  10. Night as the EP seems to be getting a hold of me and my interest in modding increases I have been considering some mods especially around the usual Intercooler, turbo, ecu, exhaust areas. I was thinking of giving the CT26 a go on the ep, something like a supra one without the twin entry, its much bigger sure to be laggy but not as big as some of the units being used and they are pretty cheap, was actually wondering how close the mounting bolt pattern would be, anyone know? Just a thought as they would be easy to source and work with.
