stewwy_94
    26
    Gloucester
stewwy_94's Achievements
  1. have you still got the loom??
  2. so will the na boost with just the map converter or do you need other software?
  3. I have a 1998 ep91 starlet and need to no wat ignition wire does wat if anyone could help that would be great cheers
  4. Ok thanks anyway
  5. I haven't got a relocator tho was going to T in to the sensor
  6. So does it still take the sensor aswel
  7. Cheers mate
  8. Ok thanks could u keep hold of it for me and i will have the money in a couple of days waiting to be paid at moment
  9. How much could u post for?
  10. Could i take an oil feed from the oil pressure switch for the turbo??
  11. It all works as it should just don't start because the injectors don't open
  12. The fuel pump is fine just put a new one in and changed the ecu and still don't start in the mornings
  13. Is this still for sale?
  14. Could it be a fault with the ecu??
  15. Its got a new pump and i have changed both temp sensors
