harrystarlet
    115
About harrystarlet
  • Birthday 12/10/1991
    Norwich
2688 profile views
harrystarlet's Achievements
  1. 1AO silver glanza bonnet wanted in good condition preferably in east Anglia area.
  2. Top seller! Buy with confidence. Thanks again mate!
  3. Nice one thank you! Yes LSD is on my list too 👍
  4. I'm currently running td04L turbo, car is going in for mapping soon and I'd like to get it over the 300hp mark. Ideally I'd like to keep the manifold set up I've got so I was thinking of using a td05, but will that be to laggy? Are there better options that will work on my manifold set up without spending a fortune? Thanks in advance Harry
  5. Top seller! Parts arrived on time very well packed and just as described!
  6. I've pm'd you mate :-)
  7. I'm sure I'd seen something about the spec clutches having an issue before on the forum, but I'm ordering some other bits from TD so was thinking about spec, but maybe I shall go with the competition stage 4 instead. Thanks for your replies :-)
  8. Thanks guys :-) What do people think to the SPEC Stage 3 clutch?
  9. What's best clutch to go for?.. for upto 300hp and keeping fairly good driveability for road use. Thanks in advance for advice 😊
  10. Plumbed it all in as the diagram shows... now I seem to have 21psi of boost, and whatever I do with the controller I can't get the boost down. I can't believe I'm having so much issues getting this working correctly 😠
  11. That's great thank you I will go and try that now ☺
  12. Just taken it up the road with boost controller of and relying on the .8bar spring in the waste gate. And it definitely boosts harder, so my problem lyes in either the plumbing of the boost controller or a faulty boost controller I guess
  13. Hi. I have a greedy profec spec 2 boost controller. I've been having issues and I can't boost past 9psi. I'm running td04 with external wastegate Piped from the turbo to the bottom port on wastegate. Then from top port to com on boost solenoid, then nc to inlet. With it set like that on idle the external gate is open and shuts once you put a few revs on. I changed it onto NO on the boost solenoid to inlet and the valve stays shut on tick over and with revs on? I'm just thinking if I've been running it the wrong way that's why I'm not getting much boost. I haven't taken it up the road like this though but I'm now not sure which way round is correct, and Google hasn't helped as there seem to be different ways on there. Any help would be appreciated Thanks Harry
  14. That would be me 😆👍
  15. Thanks for the advice guys, I will have a look over it this weekend and will let you know how I get on :-)
