Dhanley
    14
    Cork, ireland
Dhanley's Achievements
  1. hi , my bottom end recently failed on my 1E engine and i found a good bottom end replacement so im going to remove the head on my engine and attach it to the new bottom end im just wondering what the torque measurements are for the headbolts thanks
  2. Yup its a carb sound for the info il need to know everything about it first before i even attempt it haha, but am i some bit right in saying that if all the ep82 sensors were swapped to the ep91 block including the coolant housing everything should just plug straight into the ep82 loom with no splicing ??
  3. Hi i recently just bought a 1.0 ep80 starlet , and im planning on doing a turbo conversion whenever the 1.0 engine pops , My plan is to get the dashboard ,clocks,ecu, and wiring harness out of an ep82 starlet and swap everything over but as the gt engines are harder got these days im wondering would ther be much hassle in using and ep91 engine ? In my head i would just get all ep82 sensors and swap them onto the ep91 block and everything should plug and play with the ep82 wiring loom and ecu and work yes ? Please correct me if im wrong as id like to be pointed in the right way if the ep82 engine wasnt available ? Thanks
  4. Looking for a 6 puk clutch in good condition ,
  5. Pm me best price on the clutch mate
  6. As the title says , I've recently blown a gearbox and lookin to replace it but i had plans on fitting an lsd 1 anyway so i figured now would be the perfect time , im looking for any lsd box But if its oem it has to have shafts, mounts, sandwich plate and bolts Thanks
  7. this might help mate http://www.youtube.com/watch?v=wL2CZ26ltlM
  8. As above im looking for a second hand TD04 manifold and decat with external wastegate , used but must be in good condition, if nothing shows up il have to purchase new
  9. Hey funds are a bit tight at the moment , would love to buy it new from you but im afraid second hand might be my only choice atm , if i dont get sorted il be back onto you in a few weeks , cheers
  10. As the title says im looking for a half rad with mounting brackets and fan , must be in good condition , cheers
  11. Might be a long shot but are these still for sale mate ?
  12. Hi all, my spotlight come on with my dims , i can see where they spliced into the headlight loom , my question is does anybody know what colour wire to conect them to , to get them working off of the fog light switch on the stalk ? Cheers
  13. Hows things , I'm new and from cork, ireland , I'm currently converting my e11 corolla to 4efte so i joined up to get more info if i needed
