1989martin1
Member-
26 -
Newcastle
1989martin1's Achievements
Thanks for the help I couldn't see why it had holes in the shell was definitely covering this hole, just to add the lad that had it built didn't run it in at all he just went high boost from day 1, the little end is free and moving fine too I have a feeling it's possibly been oil starvation
Yeah I got the reciepts to go with it for £1100 it's all brand new parts I'm thinking the oil clearance has probably been the issue got hot and expanded then messed everything up, the main bearings are all ok no scoring etc it's literally all in cylinder 3, I also need to get the cylinder bore measured as I think it's been rebored when it was built so if I need a replacement piston and ring it'll be a larger size Would lack of oil cause this?
To say it only did a few hundred miles make me question wether it was built correctly
It's already been apart once before I bought it so that wasn't an option, I'd also say it's an oil issue but it's a brand new pump that's on, everything was changed looking at it apart from the crank
I see mate well I'll be getting a full new fuel rail and injectors if that was the cause originally it'll be hopefully gone by then, if the bearing has spun and blocked the hole would this explain the serious wear? I bought the engine to repair in the first place so it's all a learning curve this engine isn't going in a glanza though so I haven't a clue how they are built just learning off stuff on here and going from there
Cheers Colin so new crank rod and piston it is
I know mate it's in pretty bad shape to be honest, I'm going to take it next week and see what they say, I'm not sure how the oils fed into each cylinder but is there a chance the bearing spinning has blocked the feed into the piston? I think I'll just buy another rod and piston for cylinder 3 just to be safe
Well today I stripped down the 4e and found big end on piston 3 has spun, left some deep scoring on the shaft not even sure it's serviceable need some opinions Also noticed the piston is really discoloured compared to 1.2 and 4 the bore looks fine but I'm not sure wether to change the rod and piston anyway just in case Also can you buy the caps on the rods separately? I'd just like to change all of them the rods and Pistons have only covered 500 miles before the bottom end started knocking, oil pump looks alright too just wondering what my best options are from here?
Excellent thank you very much Colin I'll get the guys to check it all over and give me the sizes and the bearing sizes I need if the crank is no good I'll just get a new one
Wow I didn't realise the tolerances were so tight, The engine isn't running its knocking 500 miles after the previous owner rebuilt it, I haven't had time to check the actual shaft yet but I presume he's fucked up somewhere, so tomorrow I'll whip it out and take it into the machine shop at work and get it measured, what sizes am I looking for as in tolerance wise? Just want to know so I can either scrap it or get it ground
Ahh I get it now mate so as a standard shaft it could be between 3 sizes can you explain this to me Say my shaft is 1 43.00-43.07 am I right in assuming if I buy .25 oversized bearings the machinist will grind the shaft to 42.75 within the .07 tolerance ?
Cheers Colin I actually just want to know the diameters so I can work out if it's been done before if it has I'll just get it ground to .5 and get the oversized acl bearings I need an original reference so I know what I'm working with
Hey all Does anyone know the standard crankshaft diameters I've bought a new engine and I'm not sure if it's been reground already so I'm looking for the standard size so I can get it machined and buy the correct oversized bearings from td
Cheers dude and nah mate my brother did that a few years ago now but I've just learned from practice and reading online lol did you get that off mark bowman? Send me a message
update for you all from today, my paints reacted awfully over night and it looks like matte finish now anyways today I thought I'd have a good go at the final finishing Just to show you how bad it was before orange peel central So then I started wet sanding 2000 was taking far too long and I also read earlier today that using this rounds the edges of orange peel instead of cutting it off and flattening it so I started again with 800 pretty rough so have to be careful around the edges Then I started 1200 followed by 2000 used a diagonal sanding technique so I could see when the 800 sanding marks had been fully removed which worked really well After all of this it was polishing time used my new rotary with some G3 and a wool pad for the initial cutting took no time at all to bring it up after this I refined the finish with a much softer combination of a green hex logic pad with some poorboys ssr1 and to say the least I'm over the moon with it, to say I've never really painted anything with a gun and used a cheap gun a small compressor and I've done it all outside with no covers etc it's pretty awesome The purple under light
