junaid_11
    16
    Keighley
1215 profile views
junaid_11's Achievements
  1. Where can I get a passenger side driveshaft for my 1998 glanza v?
  2. All of a sudden my glanza v started to idle very high whilst the car is warm, it's idling all the way from 800rpm to 2000rpm, it constantly jumps up and down never staying the same, any ideas as to what could be the problem?
  3. Cheers mate, Al have to do this in morning when I get a chance Would it start leaking before it fails or would it just go all at once Though?
  4. Hi guys, As I was parking my car up yesterday I noticed that there was some fresh drops on the floor which looked like Coolant that was coming from the direction of the car. I got underneath and had a look and saw a small puddle of Coolant due to the colour and that it was not thick so couldn't be oil as I had an oil leak before but has all been sorted, the leak is coming from near the sump as far as I can see, it's on the left hand side where the timing belt is, I haven't had a chance to Jack it up and see exactly where it is coming from but any ideas? I was thinking it is most likely the water pump that has failed? The car doesn't overheat, it runs and drives as it should, I recently had the timing belt done and various other parts. Any ideas on where the leak could be coming from?
  5. How much for manifold and decat mate?
  6. My rear d2 damper has started leaking so either looking for rear d2 coilovers or rear 50mm lowering springs, got normal shocks so just need the lowering springs
  7. Hi guys, My Glanza V is in kph but I don't want to mess about converting it, I was wondering if there was any way of getting a digital little screen that will tell me my speed in mph without messing about too much? Has anyone done this before and what did you need to do it if so?
  8. Anyone got any 4x100 wheels for sale? 15x7 preferably
  9. Do you know whether the cruise wings are like the livesport? Do they widen it by 20mm or is it just the same? Yeah looks like al have to get 7j then, what wheels you running?
  10. It's an EP91, yeah mines not really slammed tbh, but if it does rub I guess I can just raise the car, what inch wheels are you running?
  11. Just wondering whether running 8j on my starlet would be too wide or not? Would I need to roll my arches, it's lowered on d2 coilovers atm about 40mm drop I think, what are you guysure running?
  12. junaid_11
    cheap glanzas
    Hi, looking for a cheap glanza. Something under 2k
